mighel84
Jun 16, 2011 2:10 PM UTC
STM8S 96 bit Unique ID on Ride7
Posted on June 16, 2011 at 16:10
I read Unique ID from address 0x48CD to 0x48D8, byte per byte, on two STM8S105C6 with functions provided by stm8s_flash.c [FLASH_readbyte()].
The results are:
x wafer: 0x001B
y wafer: 0x800D
n wafer: 0x00
lot n: 0x00312C28706431
and:
x wafer: 0x001C
y wafer: 0x002A
n wafer: 0x00
lot n: 0x002C2870643129
is ''y wafer 0x800D'' a sign-abs number?
what readout method do you use?
Thank you very much.
#stm8s-stm8-stm8s105-unique-id-96-bit-bits
    davidbleakley9
    Oct 20, 2011 10:34 AM UTC
    Posted on October 20, 2011 at 12:34
    I am also using FLASH_readbyte(), I imagine that only ST would know this. You could try tech support.
    mighel84
    mighel84Author
    Oct 20, 2011 7:50 PM UTC
    Posted on October 20, 2011 at 21:50
    Also I find out that on a STM8s105, the internal assert_param() in FLASH_ReadByte() function could catch addresses used by Unique ID, if you find problems try a simple:
    #define FLASH_UNIQUE_ID_ADDRESS         0x48CD
        for ( i=0; i < 12; i++ )
            stm8_unique_id[i] = (*((u8*)FLASH_UNIQUE_ID_ADDRESS+i));
