Steven Shenker
Apr 18, 2018 11:13 AM UTC
STM8AL3188 when performing multiple write block operations the device is freezing.
Posted on April 18, 2018 at 13:13
When performing multiple write block operations the device is freezing. I am unable to recover the device without a manual power off reset. I believe my code is correct. Could this be a driver issue? I am using IAR.
Any help would be appreciated.
Please see my code for this below:
   /* Define flash programming Time*/
   FLASH_SetProgrammingTime(FLASH_ProgramTime_Standard);
   FLASH_Unlock(FLASH_MemType_Program);
   /* Wait until Flash Program area unlocked flag is set*/
   while (FLASH_GetFlagStatus(FLASH_FLAG_PUL) == RESET)
   //inactive_image_first_block
   for (block_num=270; block_num <= 507 ; block_num++)
    FLASH_EraseBlock(block_num, FLASH_MemType_Program);
    while (FLASH_GetFlagStatus(FLASH_FLAG_EOP) == RESET)
henry.dick
Apr 19, 2018 2:27 PM UTC
Posted on April 19, 2018 at 16:27
I believe my code is correct. '
It would be a wonderful world if code works just because we believe in it.
'Could this be a driver issue?'
Possible but not probable.
When reality collides with your beliefs, it is a better strategy to check and recheck your beliefs.
Steven Shenker
May 3, 2018 12:43 PM UTC
Posted on May 03, 2018 at 14:43
To anyone else who has this problem, it was solved by dropping the clock frequency. Nothing about a requirement to do this in the datasheets however.
