Joe.H
STM8 is little endian - right?
I have started writing some STM8 code in assembler and happened upon a memory assignment issue I can't explain.
Globally I have
segment 'ram0'
Test_Word ds.w
in code:
ldw X, #$48
ldw Test_Word , X
The two bytes of memory at location Test_Word is 00 $48
This appears to be Big Endian memory assignment
if in code ...
ld A, #5
ld Test_Word , A
The two bytes of memory at location Test_Word is 05 $48
To me this is very strange.
Can someone explain why the instructions
 ldw X, #$48
ldw Test_Word , X
Did not populate memory as $48 00
Thanks in advance for any insight.
Joe
    Philipp Krause
    Senior II
    October 6, 2019
    No. STM8 is big endian.
    S.Ma
    Principal
    October 6, 2019
    if you want to make sure, make a program with a 16 bit global variable, store a value and check the 2 bytes in debug watch or memory window.
    Works for any core, and might give the answer faster than reading a programming manual.
