d_aliaga
Apr 14, 2016 7:32 AM UTC
STM8 firmware library
Posted on April 14, 2016 at 09:32
Hello
I have been reading a document called Getting Started with the STM8
and they mentioned the ''STM8 firmware library''
However I have spent a
lot
 of time (really too much) trying to find this library.
Searches inside ST homepage and googles outside proves fruitless
So I ask directly here. Can someone tell me please
where can I find the
Thanks a lot
    Ian Legg
    Apr 14, 2016 7:53 AM UTC
    d_aliaga
    d_aliagaAuthor
    Apr 14, 2016 8:35 AM UTC
    Posted on April 14, 2016 at 10:35
    Thank you very much for your reply.
    I followed your link but could not find the libraries.
    For example for the first link I found:
    -two safety packages??
    -A touch sensing library
    -A LCD software driver
    -motor control firmware
    -DALI (??) library
    -optimized examples <----- Is this the library I am looking for??
    -smart card application
    -Audio software codec
    -improvement techniques
    The second link also provided something as similarly disorganized.
    I am reading
    http://www.st.com/web/en/resource/technical/document/application_note/CD00194637.pdf
      that makes me expect (from Fig 17) something very organized.
    Where can I find and download this firmware library?
    Am I missing something?
    Did someone change the name of this library?
    Ian Legg
    Apr 15, 2016 7:09 AM UTC
    Posted on April 15, 2016 at 09:09
    The first link I posted was for the STM8S series but you need to look on page 2 and you're looking for peripheral library in the disorganised list. The second link I posted was for the STM8L series and equally if you are using this chip look for peripheral library in the list.
    Hope that helps.
    Ian
    d_aliaga
    d_aliagaAuthor
    Apr 19, 2016 1:10 AM UTC
    Posted on April 19, 2016 at 03:10
    Thank you for your help
    I found it.
    However it is not working yet... somehow it does not compile. I will start another thread and will appreciate your help there too if possible
    Thanks again
