STM32 Blue pill Freertos
I am planning to use STM32 bluepill board with Freertos. Hence trying to use Freertos API. I wanted to know how the CUBE IDE makes sure that API call to Freertos doesn't transform into an API call to Linux OS on which CUBE IDE is installed during compilation process.
Please guide.
with thanks,
B.Deepak Kumar
Andrew Neil
Andrew NeilBest answer
@bdpak wrote:
Linux OS system calls cannot be used in the CUBE IDE resulting in compilation error. Am I right?
Any calls to any stuff that's not within your Project will result in a compilation error.
EDIT:
Are you, perhaps, getting confused with Semihosting ... ?
https://developer.arm.com/documentation/dui0471/i/semihosting/what-is-semihosting-?lang=en#:~:text=Semihosting%20is%20a%20mechanism%20that,%2C%20and%20disk%20I%2FO.
Andrew Neil
Why would it even do that?
The whole point of a cross-compiler is to generate code for the Target system - not for the "Host".
mƎALLEm
As said by @Andrew Neil it's a cross compilation process meant for your target. Moreover FreeRTOS is not used by your system, why you have a doubt that the compiler would call APIs from Linux OS?
bdpakAuthor
@mƎALLEmthanks for your reply. Reason for raising such a question was to confirm that Linux OS system calls cannot be used in the CUBE IDE resulting in compilation error. Am I right?
mƎALLEm
The question is why there will be "Linux OS system calls could be used in the CUBE IDE" ?
