gavin1
Nov 22, 2006 4:32 PM UTC
Stick Low Cost Programmer Power Supply
Posted on November 22, 2006 at 17:32
gavin1
gavin1Author
Nov 22, 2006 8:08 AM UTC
Posted on November 22, 2006 at 09:08
Hello All,
I've just started using the ST7FLITE19 and I am using the ST7-STICK/UK Low Cost ICP.
The company I have joined no longer have the original Power supply for the device and I can't work out what voltage power supply to use.
There's no datasheet available so I can't see what it ought to be. Please does anyone know what it ought to be (or have the time to put a meter across the terminals.
Here's hopefully...
G.
apytel1
Nov 22, 2006 8:39 AM UTC
Posted on November 22, 2006 at 09:39
Hello
You need DC power supply 12V/200mA, with plus inside/ negative outside.
Andrzej
gavin1
gavin1Author
Nov 22, 2006 8:41 AM UTC
Posted on November 22, 2006 at 09:41
Brilliant,
Thanks!
sjo
The supply does say 12v but it is unregulated, infact very unregulated. between 13-20v has been measured unconnected.
I would supply a least 13v to the stick programmer, you may drive the opamp on the prgrammmer a bit hard with just 12v connected.
This is used to create the HDFlash programming voltage.
sjo
