STHV200 Amplifier Feature
I am trying to understand some features of STHV200 Dual channel ±100 V, high voltage 3 A linear amplifier and 2 A pulser transmitter.
I could not find a detailed datasheet of the product. Only data brief.
I want to use it to amplify the received low voltage signal. The data brief mentions an internal amplifier but I could not understand how it works. Am I able to amplify the received signal coming from the T/R switch? Or is the internal OP-AMP configurable for example as a differential amplifier?
Andrew Neil
Andrew NeilBest answer
As it's not on the website, it probably needs an NDA or other special qualification.
You'll probably need to talk to your FAE or distributor: https://www.st.com/content/st_com/en/contact-us.html
Maybe raise a support ticket: https://ols.st.com/s/
Andrew Neil
Stm325Author
I will look into that. Thank you.
