STGAP2SMTR using we design phase shift full bridge convertor
Please find the below image we design schematic and doing testing of this circuit.
This design functionality is working but during capturing the waveform of current waveform and Xfmer input voltage waveform we observed high spike as highlighted in below image.
Switching frequency: 20KHz
I/P HV: 60V
Phase shift: 50%
Dead time: 400ns
Please help me out to resolve this issue.
Let me know if you have any questions.
Thank you.
AScha.3
You are using MOSFETs to switch, so you see probably the effect of switching off a forward conducting back diode, typically they are relatively slow and produce an high current to switch them off.
MD008Author
Thank you for your quick answer.
Can you please suggest solution for this?
MD008Author
What will be the solution to make low spike?
Highly appreciate if you will be suggest the solution.
Thank you.
