Sath W
May 22, 2018 8:16 AM UTC
STEVAL-IME011V2 evaluation board - Connecting external transducer.
Posted on May 22, 2018 at 10:16
This is regarding the STEVAL-IME011V2 evaluation board based on the STHV748S 4-channel 5-level high voltage pulser. Can I please know if I can connect my own transducer to the high voltage output SMB connector, without de-soldering the on board equivalent load.
Can I also know if you think I could use this board to build a simple ultrasonic concrete thickness measuring device.
#ultrasound-pulser-ics
