STEVAL-FCU001V2 and automation
Hello everyone,
I am writing in regards to a question I have about the STEVAL-FCU001V2 board.
Is it compatible with a fully automated solution (simple trajectories and paths) ? And if so how would one implement these solutions ?
Thanks in advance,
A team of students.
It is up to you to program the application. The Eval kit is only a base for such a project.
Since this is really hard work to do it from scratch I suggest to have a look on existing projects like https://github.com/betaflight/betaflight
(Depending on where you live there might be more or less narrowing restrictions on flying objects.)
Thank you for the reply, we will look into it.
