alevinthal
Mar 23, 2010 4:24 PM UTC
startup error for 12-pole BLDC motor
Posted on March 23, 2010 at 17:24
    abelmeg2
    May 17, 2011 1:07 PM UTC
    Posted on May 17, 2011 at 15:07
    Is the fault condition Overcurrent?
    alevinthal
    No. As stated in the post, it is STARTUP FAILED.
     I have read App note AN1276 and the issue does appears to be in the alignment ramp and startup ramp table. How can I compute the correct parameter/table values for these functions? What other parameters must I set to get the system working?
    alevinthal
    I received a spreadsheet from ST online support that computes a startup ramp based on PWM freq, pole pairs, and rotational speed (rpm/s). I was able to install the new table in the code and now the motor runs fine.
