sbencke3
Jan 6, 2004 7:17 PM UTC
Startu32.a51
Posted on January 06, 2004 at 20:17
Startu32.a51
sbencke3
sbencke3Author
May 17, 2011 9:57 AM UTC
Posted on May 17, 2011 at 11:57
What is the file Startu32.a51 that all exaple code (DK3200_1~DK3200_4) use ? Where their functions are called ? Does I have to set-up something at Keil ?
joseph2399
Startup32.a51 is the very first program executed after powering up the device. In this file you can setup initial SFR register values such as prescaler value to ADC, PWM, and USB to slow down the logics, also you can disable the Watch Dog timer so you would not get periodic resets.
