gerke
Apr 12, 2008 3:51 AM UTC
Starting Problems
Posted on April 12, 2008 at 05:51
Starting Problems
gerke
gerkeAuthor
Apr 5, 2008 1:50 PM UTC
Posted on April 05, 2008 at 15:50
i'm trying to make a project with the str755fr2t6.
For the Reset-Pin i'm using the STM1813LWXF.
But i have still problems with the starting. If i switch off the power for 30 seconds or longer, the programm will not start. Then i must reset the µC and the programm runs.
What can be the problem that the programm is not running at the first try?
b.r.
Jörg Gerke
gerke
gerkeAuthor
The problem was a bad soldering joint on one of the boot pins
