lum
Mar 22, 2006 8:01 AM UTC
standby mode without external clock
Posted on March 22, 2006 at 09:01
lum
lumAuthor
Mar 15, 2006 7:08 AM UTC
Posted on March 15, 2006 at 08:08
I'd like to know if it is possible to exit from standby mode with the external oscillator disable, then enable oscillator and enter in RUN mode.
If the answer is yes, could you tell me how to proceed (which registers to set, code example... )
Thanks.
lum
lumAuthor
Mar 22, 2006 2:32 AM UTC
Posted on March 22, 2006 at 03:32
Thanks for this technical solution.
Someone told me that the external oscillator must run before the STR's wake up because the micro needs this clock to wake up. Is it true?
Does the micro use an internal clock (the RTC's 32khz for example) to proceed the wake up?
Thanks.
lum
lumAuthor
thanks for your help.
