sjayapal
Mar 23, 2006 2:57 AM UTC
Stack Size control
Posted on March 23, 2006 at 03:57
Stack Size control
sjayapal
sjayapalAuthor
Mar 23, 2006 1:40 AM UTC
Posted on March 23, 2006 at 02:40
Micro used - ST7FL35
Compiler used - Cosmic
Memory Model used - Medium Memory Model
The physical stack grows from 0x1FF to 0x180, is it possible to reduce it to say 50 bytes? if so, the expectation is that stack should grow from 0x1FF to 0x1cd. On reaching 0x1CD it should reset back to 0x1ff and start again.
-Suganya :)
fggnrc
There is no way to change the hardware range of the stack area.
If you want to re-use the stack ram, it is up to you to handle the stack overflows....
Bye
EtaPhi
