sacco_nicolas
Oct 26, 2005 10:34 AM UTC
ST92F250 - Bootloader - Access deny to E2prom
Posted on October 26, 2005 at 12:34
sacco_nicolas
May 17, 2011 9:37 AM UTC
Posted on May 17, 2011 at 11:37
We use a bootloader on our program. A problem is that sometimes the program cannot read the e2prom at the start of the micro and lauch the bootloader program. Indeed, it cannot read the e2prom flag which should tell him that the user program is present. When the bug comes, the Flash and e2prom is not readable or erasable via the ISP cable.But It uses to work very well on the ST92F120.
Maybe the new micro is more sensitive to voltage spike?
Does anyone have the same problem?
kapil
Are you using a external E2prom?
Pls check the clock at the time of communication
