johanpauvert2
Nov 25, 2002 7:11 PM UTC
ST92F150 ICP
Posted on November 25, 2002 at 20:11
ST92F150 ICP
romain2399
May 17, 2011 9:32 AM UTC
Posted on May 17, 2011 at 11:32
ICP is used wiith the ST7, the ST9 uses the In System Programing (ISP).
Refer to the datasheet for details on this protocol based on a synchronous communication at reset using the SCI-M.
The connector needed is described in the EPB User Manual that you can find on this site (http://www.stmcu.com/mdtfiles/989589078.pdf).
johanpauvert2
what headers/connections are required from me on my ST92F150 controller
board in order to perform in circuit programming ?
Skywalker
johan239955_stm1_stmicro
6 pins is all you need once you have removed the unnecessary NC and GND pins.
By the way, more information on ISP is available on the AN1450 application note (ST9 Flash Programming).
Regards,
Jojo
[ This message was edited by: jojo on 26-11-2002 00:41 ]
