frederic239955
Jun 27, 2003 7:47 AM UTC
ST92F150 electrical characteristics - I2C
Posted on June 27, 2003 at 09:47
sjo
May 17, 2011 9:34 AM UTC
Posted on May 17, 2011 at 11:34
Have alook at the phillips I2C bus spec, it gives you info about level translation at the end of the doc using fets.
I have attached if you do not have it.
Spen
frederic239955
I have some problems with ST92F150 electrical characteristics for IOs Schmitt trigger (vih,vil,hyst), especially for I2C.
For me, Hyst = Vih - Vil, but ST9 specs do not fit with this equation.
Could anyone clarify this point ?
I want to drive a 3.3V ST I2C EEPROM using ST92F150 (5V) and I need to know how to connect components . Are external pull-ups to 3.3V only required ?
(Is ST92F150 I2C peripheral compatible with 3.3V parts ?)
frederic239955
Spen,
I found information I need in I2C specs you sent me.
Thanks.
Fred.
frederic239955
Spen,
Thanks for the I2C specs.
But my question is more simple :
Is ST92F150 (5V) work with 3.3V devices with only 3.3V pull-ups on SDA and SCL lines ?
fred.
