gpr
Jul 27, 2005 4:44 AM UTC
ST9 clock speed
Posted on July 27, 2005 at 06:44
ST9 clock speed
gpr
gprAuthor
May 17, 2011 9:36 AM UTC
Posted on May 17, 2011 at 11:36
OK, got another one here, the specified range for the crystal on the ST90158 is 3 to 5 mhz. What happens if you use a slower crystal? This circuits I'm debugging uses a 2.4576 mhz crystal.
What are the possible problems?
George Richardson
Electrical Engineer
Canberra Dover
kapil
Yes you can use the said frequency but their is no garantee the device will work properly e.g ADC acuracy will not be according to the datasheet etc
