rmiucic
Jul 27, 2005 4:48 AM UTC
ST9 call routine in RAM from an interrupt routine, memory model COMPACT
Posted on July 27, 2005 at 06:48
rmiucic
rmiucicAuthor
May 17, 2011 9:36 AM UTC
Posted on May 17, 2011 at 11:36
I try to call a routine in RAM using the memory model COMPACT, so the only way to do it is using the assembly to perform a ''calls''. It works fine. But if I call this routine in RAM from an interrupt routine, I get this message from stvd9 : memory location doesn't exist ! Do I need to take care of anything else beside this ''calls'' instruction in order to perform this operation ?
Thanks if anybody can help me find out a way to do it...
:o
kapil
Try using other memory model
