marco32
Oct 19, 2005 9:17 AM UTC
ST7VD
Posted on October 19, 2005 at 11:17
ST7VD
marco32
marco32Author
Oct 17, 2005 10:20 AM UTC
Posted on October 17, 2005 at 12:20
How can i make visible compile errors in the output window of ST7 visual debug?
I get only compile commands in the output window
When i use dos prompt i see compile errors.
And how can i after compile, program or emulate the Indart?
I get GDI errors or executable errors?
Hopely someone get help me out!
laurent239955_stm1
Do you get only ''exit code = 1'' after a message explain that compiler command has failed ?
You should have checked the ''Log errors in file ...'' in the ''C Compiler'' tab in the ''Listings'' category (-e option).
Try to remove it, this work on my project.
Best regards
Laurent
