asherman
Jul 23, 2003 10:43 AM UTC
ST7Lite - Internal RC with RS232
Posted on July 23, 2003 at 12:43
asherman
ashermanAuthor
May 19, 2003 5:53 AM UTC
Posted on May 19, 2003 at 07:53
Hello All ,
I want to use the ST7Lite05 with the Internal RC oscillator and to work with the SCI (RS232) communication .
Do you think that there will be a problem with the communication in several computers because of the accuracy or not ?
Shermantec
itsmejatinus
May 19, 2003 9:54 AM UTC
Posted on May 19, 2003 at 11:54
Internal RC has an accuracy of 1% as specified into the datsheet.
sisto
Jul 22, 2003 11:31 AM UTC
Posted on July 22, 2003 at 13:31
With RC clock You will have bit sample problems during a receiver session, with higher baud rates. I have used this solution with satisfaction for baud rates lower than 2000 bps.
simonharrison9
Jul 23, 2003 6:55 AM UTC
Posted on July 23, 2003 at 08:55
I'm running at 9600 with no problem.
The only risk is when the supply changes,as this will change the clock freq.
Simon
Anglia
itsmejatinus
I have tested it from 2.4kbps to 19.2kbps without any problem with internal RC clock.
