zsavov
Dec 5, 2007 2:37 AM UTC
ST7LITE counters
Posted on December 05, 2007 at 03:37
ST7LITE counters
zsavov
zsavovAuthor
Dec 4, 2007 6:45 PM UTC
Posted on December 04, 2007 at 19:45
I read the datasheets of some of the LITE devices (ST7LITE2 and ST7LITE3). It seems to me that the 12-bit auto reload counters cannot be reset anyhow. Once the clock frequency is selected they just run forever. This means that I cannot synchronize them with any external events. Am I correct or am I missing something.
Thank you
fggnrc
zsavov1,
to synchronize the counter with an external event you can use the input capture feature.
It provides a more precise way to measure the time between two events because the timing error is limited by hardware to a clock pulse.
All you have to do is subtract the two captured values and keep track of the eventual timer overflows.
EtaPhi
