andreasfiebich9
May 26, 2005 4:05 AM UTC
ST7FMC2 MPAR register
Posted on May 26, 2005 at 06:05
andreasfiebich9
May 24, 2005 8:44 AM UTC
Posted on May 24, 2005 at 10:44
What is the MPAR register used for if DAC=1, DTE=0, PCN=0 ? i.e.
Motor controller in direct access mode, only PWM U signal connected to channel manager, dead time generator disabled !
I just want to control a brushed DC motor (only one direction includind brake) with outputs MC00 (Low side) and MC01 (Highside for braking)
alain2399
Your posted your question in the ST6 forum, you should have done it either in the ST7 or motor control one.
Post it again if you want someone to answer.
