oc_it
May 28, 2009 5:40 PM UTC
ST7FLITEUS2M6 Register File
Posted on May 28, 2009 at 19:40
oc_it
oc_itAuthor
May 26, 2009 7:38 PM UTC
Posted on May 26, 2009 at 21:38
Hello all,
I am developing with the ST7FLITEUS2M6, using ST7VD and the ST7 C library.
I cannot find an appropriate register definition file (st7xxx_reg.h) for this micro, specifically one that defines both EICR1 and EICR2 registers.
I can write my own definition file based on the datasheet, but is there something I am missing?
Cheers,
James
wolfgang2399
May 27, 2009 6:42 AM UTC
Posted on May 27, 2009 at 08:42
Hi James,
installing the st7tools, you'll get a lot of include-files in the folder include.
The file ST7FLITEUS2.h includes definitions of EICR1 and EICR2 as well.
Regards,
WoRo
oc_it
oc_itAuthor
Ah, OK. Is there an easy way to integrate those files into the existing ST7 C library structure, i.e. device selection in ST7lib_config.h (by virtue of including the device _periph.h file)? How have other approached this?
From a brief look, I guess I should do away with ST7lib_config as supplied, and write my own based on the file in that include folder...
