y2399
Jan 2, 2006 12:13 PM UTC
ST7FLITE10 and signal SIGTRAP message.
Posted on January 02, 2006 at 13:13
y2399
y2399Author
Jan 2, 2006 9:53 AM UTC
Posted on January 02, 2006 at 10:53
Hi all and thanks for reading this post.
I'm currently debugging a new code on ST7FLITE10F1M6 with ST7 Visual Debug for inDART-STX v 2.04 and inDart STX/D tool.
When I stimulate some of the inputs, I get this message : ''Program received signal SIGTRAP, Trace/breakpoint trap.
0xffff in _Tam02_asm_3_ ()''
and then the programm stop running.
I don't understand the origin of this message since I don't use any breakpoint.
Does anyone know this problem ?
Thanks in advance for your answer and happy new year.
[ This message was edited by: Akotronic on 02-01-2006 18:03 ]
y2399
y2399Author
I found the error.
Action on the input with internal pull-up resistor triggered an external interrupt. So, the associated vectors were voids and the it caused a such message.
The matter is that it is impossible to use input with internal pull-up resistor without using interrupt mode on the input.
