yoga
Jun 4, 2007 11:43 AM UTC
st7540 problem
Posted on June 04, 2007 at 13:43
st7540 problem
#power-line #test #st7540
yoga
yogaAuthor
May 28, 2007 2:53 PM UTC
Posted on May 28, 2007 at 16:53
Hallo,
I made an project with ST7540, i have problem with sending data in UART mode. Because, i can't look my result in TxOut pin with oscilloscope. Is there anyone know how to solve this problem. Because, i really need your help. I already send an e-mail into ST contact support, but until know they didn't reply me.
Thank you,
Yoga
laurent239955_stm1
Thank you for using STMicroelectroinics products and website.
This forum is dedicated to ST7 microcontrollers.
Concerning non microcontroller products (like ST7540, ST7538x, ...), you will get a better support by contacting our technical support :
http://www.st.com/stonline/domains/support/contact_support.htm
Best regards
Laurent
avilezeduardo0926
Oct 31, 2012 11:39 AM UTC
Posted on October 31, 2012 at 12:39
Hi, I'm using the ST7540 for a little system of 2 computers, after two weeks I finally accomplished read, write, and send information. But one day, the PA (Power amplifier)  stop working, so, the control loops start to working and needs more and more voltage and current, I don't know how it damage, but The ST7540 Have two test pin and I want to test it, but there's no word in the datasheet   about how work those pins (27 and 28), can you explain me how?.
Thanks a lot. Greetings from Venezuela.
