dpeter
Nov 6, 2007 8:27 AM UTC
ST7 Visual Develop and Vista
Posted on November 06, 2007 at 09:27
dpeter
dpeterAuthor
Oct 5, 2007 11:50 PM UTC
Posted on October 06, 2007 at 01:50
When I try to compile with ST7 VD (Cosmic Compiler) with Vista, I get the following errors.
access to default.wed is denied
can't create *.cx1
Any ideas??
Dave P
sg2
Quote:
can't create *.cx1
that is a problem by having no write accress to the temporary used directory - normaly the compiler use the %windows%\temp folder
(older compiler versions use root)
alternative you can set that - using option cxst7.exe -t
make sure you have write access to the path
