brian4
Aug 12, 2004 12:01 PM UTC
ST7 Lite
Posted on August 12, 2004 at 14:01
ST7 Lite
brian4
brian4Author
Aug 11, 2004 9:20 AM UTC
Posted on August 11, 2004 at 11:20
I have emailed my code to you
Many Thanks
anshul
Aug 12, 2004 11:18 AM UTC
Posted on August 12, 2004 at 13:18
I also noticed a problem in your main.asm you have referred to PADDR this is the data direction register. I am sure you want to turn the Port pin high in that case you should access the data register, PADR
[ This message was edited by: Ansh on 12-08-2004 17:33 ]
anshul
In your setup.asm
PADDR and PAOR registers are FFh which means you have configured all your ports as Push-pull output. If you want to use PA0 as an Interrupt then you should configure these registers as PADDR=FEh and PAOR=FFh.
brian4
brian4Author
I have now sorted my problem as outlined in an email I have sent you.
Many thanks for your help
