garym
ST7 In-Application Flash programming
  • December 4, 2002
  • 3 replies
  • 1023 views
Posted on December 04, 2002 at 08:01
garym
garymAuthor
Posted on October 18, 2002 at 19:59
I'm using the inDart debugger with a ''toolchain'' of Cosmic C compiler / Linker. Is there a library for ST7 in-application programming (as opposed to the In-Circuit Programming provided by inDart)?
johan239955_stm1_stmicro
Posted on October 18, 2002 at 21:34
I have not find any application note on in-application programming (IAP) with ST7. There is only the Flash programming user manual that explains you how to write code for IAP. This document can be accessed with the link below :
http://www.stmcu.com/mcdfiles/8pdf
Regards,
Jojo
maher
December 4, 2002
hi,
You find in this site two demo applications build on XFlash and HDFlash drivers
they contain :
- demo guide
- driver
- all programming environnement for thr demo (sources, drivers, config)
to try these software , use .S19 file .
and if you want to modify the software you can rebuild it by invoking the batch file.
Best Regards MM
