jl2
Apr 1, 2005 10:55 AM UTC
ST62T60C6
Posted on April 01, 2005 at 12:55
ST62T60C6
jl2
jl2Author
Mar 31, 2005 6:35 AM UTC
Posted on March 31, 2005 at 08:35
We use a ST62T60C6 to measure voltage on its CAN from a photodiode sensitive to infrared light. Sometimes, probably due to electromagnetic interferences, the microcontroller locks in a state in which it consumes something as 180mA. Then it is not able to acomplish any of its tasks, its oscillator doesn't work. Even a reset signal doesn't manage to restart it. It must be turned off before working good again.
[ Ce message a ete modifié par : : GIELLEM on 31-03-2005 12:08 ]
joern2
This is probably a latch-up. You are pulling a port pin below Gnd or above Vcc with a higher current. If you do not limit the supply current during this state you destroy your uC.
Have a look on the maximum ratings in the datasheet.
Best regards
