mahdiyeh_ghazi29
Apr 28, 2011 7:23 AM UTC
st6 eprom programmer
Posted on April 28, 2011 at 09:23
hello every body,
I have a problem using st6 eprom programmer with WINEE software,
I use WINEE software to program st62T03C so I connect the board to PC using
serial port
and set all the project configuration which are required in WINEE but the problem is that when we want to
blank check
the eprom we got this message ''! EPROM area not blank'', we got this message even if there isn't any micro in the board, the jumper is set in remote mode.
previously I programed this micro with the same code using st6 starter kit and everything was ok, but now I dont know what the problem is.
thanks in advance
