p-alain
Jun 2, 2005 3:31 AM UTC
ST10F276 save data in XFlash
Posted on June 02, 2005 at 05:31
p-alain
p-alainAuthor
Jun 2, 2005 2:51 AM UTC
Posted on June 02, 2005 at 04:51
I work with the St10F276 and Keil.
Could somebody explain to me how i could save permanent data in XFlash before shutting down my st10. And how I could read it at the next start.
Thank you.
najoua
To be able to access the ST10F276 XFLASH module, please make sure that:
- flash is enabled by setting ROMEN bit in SYSCON register.
- XFLASH is enabled (by setting XFLASHEN bit in XPERCON register and XPEN bit in SYSCON register) in order to be able to access the flash registers.
- SMOD bit in FCR0H register is cleared otherwise the write operation will be performed on IFLASH module.
Have a look to the ST10F276 datasheet, page 74 (''Write Operation Examples'' section 5.6) where good examples are given and i am sure that they will help you.
Najoua.
