jas
Feb 14, 2007 4:19 AM UTC
ST100P Ethernet PHY chip
Posted on February 14, 2007 at 05:19
jas
jasAuthor
May 17, 2011 7:36 AM UTC
Posted on May 17, 2011 at 09:36
I notice this is used on the STR91x EVAL board. Is it OK for new designs or likely to become obsolete in the near future ?
Can you recommend an alternative MII PHY device please.
Thanks.
jas
jasAuthor
Quote:
I am using Davicom DM9161AEP with Taimag RJLBC-060TC magnetics - it works, it is RoHS and I can buy it from Dacom West GmbH.
Are you using this chip in MII or RII mode ?
I am not an ethernet expert, therefore I have to rely on ST example software, they use MII interface which requires many more pins to interface to STR91x
[ This message was edited by: Arm_Wrestler on 13-02-2007 12:39 ]
heiko2399
Hello!
jas
jasAuthor
Hello fellow STR91x users.
I've had a look at various STR91x and other evaluation boards and here is what they use for the ethernet PHY device:
Keil DP83848
ST STE100P
Atmel DM9161AE
IAR STE100P
I think I will use STE100P, there seems to be more info and demo s/w for it.
heiko2399
I am using MII. There are some special registers on the chip, but I guess it should work by using example from ST - but I don't try it.
