adronico
ST10 In-Circuit Programming
  • August 7, 2003
  • 928 views
Posted on August 07, 2003 at 15:23
adronico
adronicoAuthor
Posted on June 11, 2003 at 08:47
I'm trying to reprogramm a ST10F269-T6 device which is already mounted on a circuit. The St10 MCU is monitored by a L4969 device(system voltage regulator with a CAN Transceiver). I'm failing to get the MCU in Bootstrape mode. The problem is probably the watchdog on the L4969 device. How best can I deactivate this watchdog.
thank you!
guenther
August 7, 2003
I really don't know the L4969, but try this:
The RESET state of the ST10 IO pins is HiZ. So trigger your watchdog input with an external oscillator and enter an undisturbed boot.
hope it helps...
