Philip Haasnoot
ST Visual Developer says ''out of memory'' and crashes when trying to launch the programming tool
  • December 6, 2017
  • 11 replies
  • 7299 views
Posted on December 06, 2017 at 19:37
I have been using ST Visual Developer for 6 months without this issue. I was having problems with a project I am working on and thought that re-installing the tool might help. Once I un-installed the tool and installed the latest version the program will either crash after a few minutes, or crash immediately when launching the programming tool. It gives me the error message 'Out of Memory'
Any resolutions to this issue?
    S C
    Posted on December 08, 2017 at 11:43
    The 'out of memory' error makes think about issue with ever growing .wed and .wdb files, which should be deleted in this case (see also chapter 3.3 of STVD release notes). The crash with the programming tool is confirmed with STVD-4.3.12; it might be workarounded by using stvp/tools.cnf file from previous version (STVP-3.4.0) attached here (keep a copy of the original file if wanting to use STVP-3.4.1 later, without having to reinstall). The real fix will be provided later.
    If the crash persists, please join the file stvd/stvd_pm.log in order to allow easier investigations.
    ________________
    Attachments :
    tools.cnf.zip : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006HyEY&d=%2Fa%2F0X0000000b5C%2F1sIa3iUbq_l7hHViMuRMVO70mBHfGIeHGCYM2UsURVA&asPdf=false
    sge sg elettronica
    April 20, 2018
    Posted on April 20, 2018 at 13:22
    the file tool.cnf does not exist in my installation, even if it does not work, the defect remains
    LaurentL
    Posted on April 20, 2018 at 14:15
    It's in STVP directory, not STVD !!!
    You must have this file...STVP wouldn't working in standalone mode.
    Rgds,
    Laurent
    Scott Yanke
    March 3, 2018
    Posted on March 04, 2018 at 00:56
    I am also using STVD-4.3.12.  Replacing the tools.cnf file in the stvp directory corrected the crashes that I was experiencing when trying to use the programmer from STVD.  Thank you for supplying the workaround.
    Lctasca
    August 14, 2018
    I was not able to download the attached file, could someone post it again?
    SMiro
    August 26, 2018
    The file is not available. Can you re-attach please?
    henry.dick
    Use a real ide and you don't to worry about that problem.​
    S C
    A fix consists in updating the file stvd/ProgrammerAddOn.dll to version 1.3.3.0 joined​
    Lyang.5
    March 10, 2021
    hi, i also  use STVD-4.3.12. Replacing the tools.cnf file and ProgrammerAddOn.dll file in the stvp directory corrected the crashes that I was experiencing when trying to use the 'Tools-Options' from STVD ,which cannot solve the problem.
