georg23
Mar 3, 2010 8:11 AM UTC
ST-Link requires admin rights...?
Posted on March 03, 2010 at 09:11
hi all,
apparently the ST-Link requires admin rights to allow program/debug. Specifically I observed that I can only program the STM8 ''Discovery Kit'' from my admin account, not the one with restricted access. Is this intended?
PS: I run Windows XP SP3 with STCD v4.1.4
Thanks in advance,
Georg
    martinglunz9
    Mar 4, 2010 9:33 AM UTC
    Posted on March 04, 2010 at 10:33
    Hi
    I've got the same issue.
    There's a convenient workaround possible (at least for me):
    edit the desktop shortcut to the toos to use runas /savecred
    Just add ''runas /savecred /user:admin_accout to the Target, e.g.:
    C:\WINDOWS\system32\runas.exe /savecred /user:admin_account C:\Programme\STMicroelectronics\st_toolset\stvp\stvp.exe
    thomasblender9
    Mar 6, 2010 6:33 PM UTC
    Posted on March 06, 2010 at 19:33
    I had the same problem. I solved it in Windows 7 by edit the properties of C:\Program Files\STMicroelectronics\st_toolset\stvd\stvdebug.exe.
    Change to tap compatibility and enable run as admin.
    georg23
    georg23Author
    Mar 15, 2010 11:29 PM UTC
    Posted on March 16, 2010 at 00:29
    hi,
    sorry for the late reply, I was on a business trip and had forgotten my discovery board...
    I will need to check your tipp at work, where I have the problems. However, I suspect that the (very) restricted access rights on my office PC prohibit the use of ''runas''. I'll report tomorrow...
    Regards,
    Georg
    georg23
    georg23Author
    Mar 17, 2010 6:50 AM UTC
    Posted on March 17, 2010 at 07:50
    hi again,
    as expected, the access restrictions prevent using ''runas'' on my office PC. My workaround is using an external RLink instead of the built-in ST-Link. At home I use the ST-Link. Not a nice solution but it works for me. Anyway, thanks a lot for your feedback!
    Regards, Georg
