algontsov
Jul 11, 2010 6:37 AM UTC
ST 10 Flasher 2.4b dumping error
Posted on July 11, 2010 at 08:37
ST 10 Flasher 2.4b can flash any ST10 due to the same init commands.
But it's can't dump the flash, even if the port and monitor are fine. Every thime the same:
*Dump-->ERROR
Description: LoadExternalFlashMonitor: target Not found
Only a writing of the hex-file is possible.
Anybody knows how to start a flash dumping using this tool? Maybe it's just prohibited by ST policy and not included in that free soft...
#st10-flasher-dump
ricardo23
Feb 14, 2011 3:43 PM UTC
Posted on February 14, 2011 at 16:43
I having the same problem. You solved it?
