martinkorn
Sep 22, 2006 4:28 AM UTC
SRAM mapping
Posted on September 22, 2006 at 06:28
SRAM mapping
martinkorn
May 17, 2011 7:32 AM UTC
Posted on May 17, 2011 at 09:32
Is there a possibility to map the internal SRAM to address 0x00000000 ?
So I would be able to use the interrupt vectors without writing to the flash.
shangdawei1
i can not found info about it.
only Flash B0/B1 can be mapped to 0x00000000.
how to ?
martinkorn
Thanks for your help. I will try the vector jump table.
Cheers
Mako
sjo
The only way is to put a vector jump table in flash, pointing to ram.
sample attached.
Cheers
sjo
