ranjeet_malhotra
May 17, 2011 7:54 AM UTC
Posted on May 17, 2011 at 09:54
We are using STR910FAM32 and we are using the SRAM for code and data storage. From the Data sheet it appears that the SRAM is mapped in three regions:
0X0400 0000 - SRAM D-TCM
0X4000 0000 - SRAM, AHB BUFFERED
0X5000 0000 - SRAM, AHB NON-BUFFERED
Would it possible for someone to advice which of the three regions should be used and what are the advantages/limitations of doing the above in each of the three regions.
thanks.
regards, Ranjeet
