blji
May 30, 2006 5:35 AM UTC
spi problem str7xf
Posted on May 30, 2006 at 07:35
spi problem str7xf
blji
bljiAuthor
May 25, 2006 6:53 AM UTC
Posted on May 25, 2006 at 08:53
Hi
I have a problem in SPI to have communication work from slave->Master.
Use str7 library.
BSPI_BSPI0Conf(ENABLE);
BSPI_Init ( BSPI0 ) ;
BSPI_ClockDividerConfig ( BSPI0, 6);
BSPI_Enable ( BSPI0 , ENABLE );
BSPI_MasterEnable ( BSPI0,ENABLE);
BSPI_ClkActiveHigh(BSPI0,ENABLE);
BSPI_ClkFEdge(BSPI0,DISABLE);
BSPI_8bLEn(BSPI0,ENABLE);
BSPI_TrFifoDepth(BSPI0,9);
BSPI_RcFifoDepth(BSPI0,3);
I do have same functions for slave except
BSPI_MasterEnable ( BSPI0,DISABLE);
When I send byte from slave-> master is not working. But Master->slave works.
Also I have another issue in strxf I am not able to make spi1 function as master and spi0 slave.
blji
alain2399
Hi, I think that you posted your question in the wrong forum, as it is related to ARM STR7 nad not ST7 you should have posted it in the ''ARM7 STR7'' forum:
http://mcu.st.com/mcu/modules.php?mop=modload&name=Splatt_Forums&file=viewforum&forum=17
