sr_shinde
Aug 22, 2008 9:53 AM UTC
SPI Problem
Posted on August 22, 2008 at 11:53
SPI Problem
sr_shinde
sr_shindeAuthor
May 17, 2011 7:55 AM UTC
Posted on May 17, 2011 at 09:55
Hi all,
I got solution. I had connected NSS of my master to Nss of slave.But If uc is in master mode NSS has to be connected to VDD(high).Otherwise u will get loopback effect .U will receive whatever u have transmitted.
Sai
sr_shinde
sr_shindeAuthor
Hi All
I have configured SSP0 of STR912.
configuration is as follows:
/* SSP0 configuration */
SSP_InitStructure.SSP_FrameFormat = SSP_FrameFormat_Motorola;
SSP_InitStructure.SSP_Mode = SSP_Mode_Master;
SSP_InitStructure.SSP_CPOL = SSP_CPOL_Low;
SSP_InitStructure.SSP_CPHA = SSP_CPHA_1Edge;
SSP_InitStructure.SSP_DataSize = SSP_DataSize_8b;
//for 1.4 kbps
SSP_InitStructure.SSP_ClockRate = 150;
SSP_InitStructure.SSP_ClockPrescaler = 228;
SSP_Init(SSP0, &SSP_InitStructure);
SSP_LoopBackConfig(SSP0, DISABLE);
SSP_Cmd(SSP0,ENABLE);
Then I am checking
while(SSP_GetFlagStatus(SSP0, SSP_FLAG_TxFifoEmpty) == RESET);
and then transmitting some data
After that waiting for response
/* Loop while Transmit FIFO is full */
and reading value
data = SSP_ReceiveData(SSP0);
I am getting same data that I have transmited
I am getting same result whether slave is connected or not.
I have disabled LoopBack mode.
Please help me solve the problem.
Sai
sripad
Thank you for your valuable input dear friend!
