mariusz2
Mar 21, 2008 2:43 PM UTC
Software reseet in str 911fm44 how?
Posted on March 21, 2008 at 15:43
mariusz2
mariusz2Author
May 17, 2011 7:43 AM UTC
Posted on May 17, 2011 at 09:43
Hi all, How to make reset in str 911fm44 (software, without WDG timer)
You have some code example ?
stefano239955_stm1_stmicro
Through the Peripheral reset register SCU_PRR0 and Peripheral reset register SCU_PRR1 it is possible to force the reset for each peripheral.
roger_lynx
It is very simple!
asm(''MOV PC,#0x00'');
Okay, this might be very simple if you dont't care about the state of the HW registers (incl. peripherals) prior to performing this type of ''warm boot'', as suggested.
Many times one cares about the initial conditions being at a known state - which only a real reset (ext. or powercycle) will provide.
usatyj
It is very simple!
mark9
I've been looking for the answer for this for a while, and it seems the best answer is to enable the Watchdog (WDG) and do a while(1); to force it to reset.
