luter
Feb 9, 2006 8:14 AM UTC
SofTec inDART-STX/D and 12v on Vpp/ICCSEL
Posted on February 09, 2006 at 09:14
luter
luterAuthor
Feb 9, 2006 6:25 AM UTC
Posted on February 09, 2006 at 07:25
Hello.
I am going to write IAP bootloader. To erase/write flash i need 12v on Vpp/ICCSEL pin. By the way i use SofTec inDART-STX/D that uses the same pin for its own purposes. As i determined, debugger puts 12v on this pin during erase/write at the beggining of debug session. I am not so crazy :) to develop bootloader without debuger. Is there any possibilities to have both debugger and 12v and not to damage debugger?
The easiest way is to use switch to connect/disconnect debugger and 12v.
Any another ideas?
Viktor POHORELY
Feb 9, 2006 7:54 AM UTC
Posted on February 09, 2006 at 08:54
What about to use Schotky Diode in between your application and InDART?
Maybe BAR43C could be nice, dual schotky in one package - one for InDART, one for your application....'?
luter
luterAuthor
Easy solution :-]
Tnx a lot.
