jason239955_st
SMT8 for OTA solution
Hi Sir/Mdm,
Would like to know is there any solution for OTA (Over-the-Air) upgrade firmware for STM8?
Regard's
Jason
    November 5, 2019
    If you can erase/write the FLASH from within your own code/application, and you have enough space to hold the new firmware, you can likely create any kind of OTA or field update method you want.
    JAhme.2
    January 24, 2022
    Do you have an example code for the OTA firmware update?
    jason239955_st
    Do you have the solution or reference code?
    November 5, 2019
    jason239955_st
    Hi Sir,
    Does this will work for STM8S005?
