Those are spots of glue to keep the resistors from moving around when they are placing them. They serve no electrical purpose.
Andrew Neil
@TDK wrote:
Those are spots of glue to keep the resistors from moving around .
doesn't seem to have worked in this case!
Likely the part was intentionally not loaded and the glue stencil wasn't modified. Also note solder paste on those pads--same reason.
