SMusc.1
SMD devices
Hello everyones, what are the red marked devices in smd format, diodes maybe? They are grey and yellow. There are no label on them.
Andrew Neil
Andrew NeilBest answer
Again, don't forget to mark the solution.
BTW: note that "SMD" = Surface-Mount Device - so "SMD device" is a tautology.
See also: LCD display; RAM memory; etc, ...
Those are ceramic capacitors.
SMusc.1
SMusc.1Author
thank a lot
Andrew Neil
