brian4
Apr 16, 2007 9:09 AM UTC
Send text (addresing problem assembler)
Posted on April 16, 2007 at 11:09
brian4
brian4Author
Apr 16, 2007 7:14 AM UTC
Posted on April 16, 2007 at 09:14
Hi all
Having a bad day, simple problem but I just cant figure out the syntax
I have some text messages I am sending out on a pin, I now have the TX pin routine working.
In Assembler I want to write a routine to send each string. The strings are stored as Mess01, 02 etc.
I assume I use A,([ptr.w],X) to read the string in where X = Character position
In ROM segment I have
.Mess01
STRING ''Power On Reset''
DC.B $0D
.Mess02
STRING ''Test In Progress''
DC.B $0D
My simple question is how do I read the location (16 bit) of Mess01 or 02 etc and save that in ptr.w location
Not done much with index addressing before.
Re Brian
wolfgang2399
Apr 16, 2007 8:56 AM UTC
Posted on April 16, 2007 at 10:56
Hi Brian,
it seems not to exist a fixed rule. The code to use depends on your compiler.
The original ST asm7 works with the code (not tested!)
LD A,#Mess01.l
LD {ptr+1},A ; curly brackets!!
LD A,#Mess01.h
LD ptr,A
while my compiler needs the syntax
LD A,#LOW(Mess01)
LD ptr:1,A
LD A,#HIGH(Mess01)
LD ptr,A
WoRo
brian4
brian4Author
Thanks for that
Just found the .h & .l in a Link USER manual PDF and I have just typed the same as you suggested, all works ok.
One other slight funny
In my data.asm file I have defineed
ptr.w 1
However if in my data.inc file I state EXTERN ptr.w I get and error?
Error 54: Can't match Addressing mode ' ld A,([ptr.w],X)
but if I state EXTERN ptr.b I get no errors and all works.
Re Brian
