adib
Sector 0 size definition question
  • May 27, 2004
  • 4 replies
  • 761 views
Posted on May 27, 2004 at 12:47
adib
adibAuthor
Posted on May 26, 2004 at 15:22
Can someone please tell if resizing sector 0 to 0.5K will increase sector 1 size?
If not what is the purpose of resize able sector 0?
sjo
Posted on May 27, 2004 at 07:25
The idea behind resizing sector0 is only for In Application Programming (IAP) reasons.
You are able to choose a sector size as close to the size of your iap firmware, and so trying not to waste valuable memory space.
Changing the size of sector0 will effect the size of sector1, but it will not change the total available flash memory.
For most IAP applications 0.5-1K sector0 will be enough.
sjo
[ This message was edited by: sjo on 27-05-2004 10:56 ]
adib
adibAuthor
Posted on May 27, 2004 at 10:43
Thanks very much.
Do you know what will happen if I in IAP accidentally write to sector0? will it damage the micro?
sjo
You cannot write to sector0 with IAP - it is read-only.
Sector0 is only accessable via ICC mode entry.
sjo
