saranyim
Nov 30, 2010 7:04 AM UTC
section boundary crossing
Posted on November 30, 2010 at 08:04
    luca239955_stm1_st
    May 17, 2011 1:11 PM UTC
    Posted on May 17, 2011 at 15:11
    you must compile your application with a ''>64k'' memory model (one of those that do not end with ''0'') and matching libraries.
    Regards,
    Luca
    saranyim
    saranyimAuthor
    Thank you Luca but could you please guide me how to do that?
    I use STVD + Cosmic (CX STM8) and using firmware libraries from ST
    I looked in menu Tools -> Setting in C Compiler tab and made change on Memory model  to Long Stack(+modsl0)
    if I use short stack I have problem with zero page oversize.
    I look around in the forum I found some that point to change to >64k model but I could not find that setting,
    Regards,
    Saran
    saranyim
    saranyimAuthor
    Found the solution!!
    When select +modsl will generate the error ''f__stext not defined''
    then go to stm8s_it.h line number 35
    look for ''void _stext(void); /* RESET startup routine */''
    and edit to ''
    extern @ near void _stext ();''
     then problem solve
